Closed loop still broken
Posted: Tue May 22, 2007 1:54 pm
by blundar
I'm using 1.1.8r5 with rom .40 If you enable closed loop, car seems like it runs ok but there isn't any targeting of O2 voltage If you enable closed loop AND O2 heater, car runs like shit. I'll post binaries later.
Posted: Tue May 22, 2007 2:42 pm
by Civic Tsi
Posted: Tue May 22, 2007 3:15 pm
well i have to check later then.. In 2 hours i'll start testing...
Posted: Tue May 22, 2007 5:33 pm
can somebody send me binary and logs please? Edit: Sure \"Wideband as closeloop input\" was not on? Then you will get strange things
Posted: Tue May 22, 2007 8:58 pm
I did some testing today. 3 hours total I tested with rom 41 but it's the same as 40 expect EBC stuff. No weird things.. I need info what is wrong.. I tested both \"Disable Closeloop\" and \"Disable closeloop and disable VE(stock)\" I saw the trim moving up and down around the target. I couldn't test with o2 heater because i don't have 1. Dave... If you have the wideband closeloop on it flips the carry.. Narrow band volatage higher means richer... Leans the trim Wideband closeloop higher means leaner... Rich the trim So that could be the problem.. Closeloop should be all good i think... I need more tester... With calibrations, logs.. documented what is going on
Posted: Wed May 23, 2007 4:39 pm
by blundar
Look at these. Bone stock 1994 USDM F22B1 motor with stock exhaust, header, you name it. You can add this calibration to eCtune, Calvin. It runs decent for a street tune - the motor is a slug tho. Completely lacks top end.
Posted: Wed May 23, 2007 5:00 pm
logs?
Posted: Wed Jun 20, 2007 12:28 pm
by nate
Dave, What is the status on this?
