eCtune Freeze - Forced Hard Restart of Laptop
marshall.hagen
First, let me say after tuning my first car on eCtune, this software absolutely blows CROME out of the water. I am very impressed on eCtune's functionality for being a ROM editing platform. There are very few features a full standalone can offer that eCtune does not. Now that I've got that off my chest, I need some help diagnosing a problem. I seem to be experiencing the same problems as these two: eCtune Freeze eCtune Freeze 2 Hardware summary: JDM OBD1 PR3 B16 ECU Ostrich 2 Hulog2 Xtreme POS Dell laptop Windows 7 2gb RAM / 1.8 Ghz AMD 64bit Fresh FTDI install (and clean) as of 9/6/2009 I never get any connection errors with the emulator or datalogger The freeze happens usually during datalogging, but has happened in just general live-sensor view a couple times. The entire computer completely freezes and forces a hard reboot. The good thing is that the datalogs up until the freeze are still stored in memory upon restart, so I am not wasting a bunch of time (just the ~4 minutes or so between restarts). Since there are two instances above where others have experienced the same problem (and possibly more...), I was hoping to find a solution from someone. I have a feeling it has something to do with Windows 7. I did a fresh FTDI installation and clean as per Calvin’s recommendation in one of the linked threads above, but that did not solve the problem. Thanks.
marshall.hagen
I'm having the same problem. I think I have the same driver (can't check right now) and have the same latency setings. those were the recommended settings i found somewhere, although I noticed the xenocron support section suggests setting latency to \"1\" for both devices. i'll install the latest FTDI drivers (2.4.16) tomorrow. *edit Checked out FTDI's changelog and found some bugfixes wich might be related: 2.04.06:
- Fixed deadlock issues for multi-processor systems. Fixed lock-up problem in Vista and XP.
marshall.hagen
Thats odd that after I performed the FTDI clean and installed a fresh download of VCP drivers, the laptop still shows 2.2.14 as the current version. I will try again tonight to FTDI Clean and download the driver pack again. I will be touching up my map next week, so I can hopefully get this issue resolved!
I can confirm that the 2.2.4 drivers are bad. I've upgraded to 2.4.16 and the hard lockups are gone. I've done 2 20-30min datalogs now withouth any problems. For anyone with lockup problems, download these latest drivers: http://www.ftdichip.com/Drivers/CDM/CDM ... tified.zip Do a manual driver update (from within 'device manager')'. No need to do a driver cleanup. Just choose update driver, and choose to manually select the driver (don't let windows search). Then select ftdiport.inf for the virtual comport driver. I set buadrates back to default, and latency to 1. No problems so far.
