				eCtune Freeze - Forced Hard Restart of Laptop
				Posted: Wed Sep 09, 2009 10:01 am
				by marshall.hagen
				First, let me say after tuning my first car on eCtune, this software absolutely blows CROME out of the water.  I am very impressed on eCtune's functionality for being a ROM editing platform.  There are very few features a full standalone can offer that eCtune does not.    Now that I've got that off my chest, I need some help diagnosing a problem.  I seem to be experiencing the same problems as these two:
eCtune Freeze  eCtune Freeze 2    Hardware summary:  JDM OBD1 PR3 B16 ECU  Ostrich 2  Hulog2 Xtreme  POS Dell laptop   Windows 7  2gb RAM / 1.8 Ghz AMD 64bit  Fresh FTDI install (and clean) as of 9/6/2009  I never get any connection errors with the emulator or datalogger    The freeze happens usually during datalogging, but has happened in just general live-sensor view a couple times.  The entire computer completely freezes and forces a hard reboot.  The good thing is that the datalogs up until the freeze are still stored in memory upon restart, so I am not wasting a bunch of time (just the ~4 minutes or so between restarts).    Since there are two instances above where others have experienced the same problem (and possibly more...), I was hoping to find a solution from someone.  I have a feeling it has something to do with Windows 7.  I did a fresh FTDI installation and clean as per Calvin’s recommendation in one of the linked threads above, but that did not solve the problem.    Thanks.
				Posted: Wed Sep 09, 2009 2:03 pm
				what is your driver version?  What is the latency of the FTDI drivers?
				Posted: Thu Sep 10, 2009 9:58 pm
				by marshall.hagen
				calvin wrote:what is your driver version?  What is the latency of the FTDI drivers?
    Ostrich2 (COM 4)  2.2.4.1 FTDI  Latency 10 msec    HuLOG Xtreme (COM 5)  2.2.4.1 FTDI  Latency 2 msec
				Posted: Mon Oct 19, 2009 7:40 pm
				by Pandor
				I'm having the same problem.    I think I have the same driver (can't check right now) and have the same latency setings.    those were the recommended settings i found somewhere, although I noticed the xenocron support section suggests setting latency to \"1\" for both devices.    i'll  install the latest FTDI drivers (2.4.16) tomorrow.    *edit    Checked out FTDI's changelog and found some bugfixes wich might be related:
2.04.06:- Fixed deadlock issues for multi-processor systems.  Fixed lock-up problem in Vista and XP.
				Posted: Tue Oct 20, 2009 10:11 am
				by marshall.hagen
				Thats odd that after I performed the FTDI clean and installed a fresh download of VCP drivers, the laptop still shows 2.2.14 as the current version.    I will try again tonight to FTDI Clean and download the driver pack again.    I will be touching up my map next week, so I can hopefully get this issue resolved!
				Posted: Tue Oct 20, 2009 5:07 pm
				by Pandor
				I can confirm that the 2.2.4 drivers are bad.  I've upgraded to 2.4.16 and the hard lockups are gone.  I've done 2 20-30min datalogs now withouth any problems.    For anyone with lockup problems, download these latest drivers:
http://www.ftdichip.com/Drivers/CDM/CDM ... tified.zip    Do a manual driver update (from within 'device manager')'. No need to do a driver cleanup.  Just choose update driver, and choose to manually select the driver (don't let windows search).  Then select ftdiport.inf for the virtual comport driver.    I set buadrates back to default, and latency to 1.  No problems so far.
				Posted: Thu Nov 05, 2009 8:23 am
				good
