what does it mean?
Posted: Thu Nov 05, 2009 4:11 pm
by vtecturbo
PRO License Includes: Live graphs (RPM vs AFR/Boost, Time vs AFR) Quad stage boost controller Electronic Boost controller with closeloop support(EGR/AT Lockup) Lean Protection Load Indexing(Map sensor, Tps Sensor, Alpha-N or combination) 24x20 fuel and ignition maps Secondary maps: ITB support, Low/High Octane, etc General Purpose Outputs with fuel/ign corrections Ability to import/export maps Extra analog logging inputs Extra inputs (ELD/EGR/b6) for wideband Wideband closeloop and selectable closeloop input Smart/Live tracking Direct serial wideband access for(PLX, Innovate, FJO, Tech-Edge, Zeitronix, AEM, JAW) Moates Ostrich 1 and up support Moates Demon v1.2 and up support: Note eCtune will support on-board datalogging with the demon. Note: Only allows tuning one car (for more cars, contact us) Unable to open/save binary files ???????????????????????????? Moates Demon usable on multiple laptops(not bound to one laptop) Support (3 months): Direct IM support Skype (VOIP support) Forum support Direct mail support Exclusive access to maps, tunes and technical data Updates/License duration: 1 year license and updates (What does this mean?) its ectune pro features .please explanation for thıs feature Unable to open/save binary files
Posted: Thu Nov 05, 2009 9:40 pm
by james25
That is a feature of the Tuner version/license of ectune which allows you to save a bin that you created and burn onto a chip. Pro version doesn't have that feature so an Ostrich emulator is needed to store the data you create.
Posted: Thu Nov 05, 2009 10:43 pm
by relic1
a bin file is what is able to burned to a chip, the PRO license allows you to push the tuning information to an emulator (like an ostrich) which works just like a chip, but with pro, the emulator has to remain in the ECU at all times. With Pro you save what's called a cal file, this has all the information like the fuel and ignition maps as well as all the tuning information for the car, but this file is unable to be burned to a chip. the TUNER license does everything that pro does (and a little more) but the main difference is it allows you to save the tuning info to a bin file for chip burning. This allows you to pull the emulator out of the vehicle and tune another car with it. pro - designed for a single user tuner - designed for a shop or tuning business
Posted: Fri Nov 06, 2009 4:41 pm
by vtecturbo
thanks for explanations.
