Which Basemap for High Compression B20 vtec?
Posted: Tue Nov 24, 2009 1:40 pm
I installed an RMF (replica) narrow header over the weekend, and feel like a re-tune is in order to get the max out of it. Since I'm going to re-tune, I figure I should start the tune from scratch and see what I can do. Which basemap should I start with? I used the P72 before, not sure if that was as close to what I need as I can get. Here's the setup: Fully Balanced B20B RS Machines 12.5:1 CR pistons (Type R replica) (actual compression is probably over 13:1 after block decking and head resurface x2) Stock B17 head w/ GSR cams Skunk2 Pro IM 330cc injectors @ stock fuel pressure RMF narrow replica full 2.5\" exhaust
