Vacuum leak fuel cut
Posted: Fri Dec 25, 2009 5:52 pm
by ckretvix
Does this work via just reading TPS to determine when to cut fuel?
Posted: Thu Jan 14, 2010 10:28 pm
by ckretvix
bump, can someone explain this please?
Posted: Fri Jan 15, 2010 12:20 am
The stock ECu has a routine that prevents the car from over revving if you have a vaccume leak.. Bascally if it sees to high of an idle speed with the TPS below a certain threshold it will momentarily cut fuel to lower the RPMs.. This is why when you have a vaccume leak the car will rev then bog then rev then bog, when your sitting at idle.. The check box just disables this feature.
Posted: Fri Jan 15, 2010 1:08 am
by ckretvix
Ok great; thanks.
Posted: Tue Jan 19, 2010 7:16 pm
thanks burgermass!
