Does the new update alter tune?
Will any of the new updates change current tunes, specifically these items 0.0.2.3 r9 PRI edition rom 0.0.65 -Fix Fuelcut settings (TPS AND MAP) thershold fixed - X - dwell correction -rpm phase table -human readable values - X -extended range to 11k rpm - X -battery offset phase multiplier table -Human readable values - X - stock ign limitations based on rpm row -Default disabled by eCtune sinse rom 0.0.46 -X My fuel cut is setup properly, as is the rest of my tune. The \"dwell corrections\" etc will not change anything other than the way we view the tables correct?
The vacuum leak disable is there, hopefully the new fuel cut settings dont mess with how I currently have it set. It works perfectly as is for me. Guess we will find out in March when the snow goes away. As far as all of the timing settings though, it is just a different user interface correct, the actual engine timing remains the same?Bugermass wrote:Fuel cut now currently works like its supposed too.. Calvin and I hashed it out at PRI.. Also not sure if its available on the single user ver, but theres a disable check box for the fuel cut that happens when you have a vaccum leak..
correctsohcd16y8 wrote:The vacuum leak disable is there, hopefully the new fuel cut settings dont mess with how I currently have it set. It works perfectly as is for me. Guess we will find out in March when the snow goes away. As far as all of the timing settings though, it is just a different user interface correct, the actual engine timing remains the same?Bugermass wrote:Fuel cut now currently works like its supposed too.. Calvin and I hashed it out at PRI.. Also not sure if its available on the single user ver, but theres a disable check box for the fuel cut that happens when you have a vaccum leak..
