Can't connect to ECU with Hulog
So i woke up this morning to get ready to go on the Dyno, emulator connects just fine, hulog can't connect with ecu for some reason. the only thing i did different was the latest eCtune update. any ideas?
adn i installed a 5151S high side switch into IC16 for my EBC in my P30 ecu. it originally had the 5050 there, would that work with the EBC instead of the 5151S? Also, i did not put the 1n4004 diode into d13, there was already a diode there. as it sits right now, the EBC works just fine. Would not using the 1n4004 diode in d13 cause the hulog to not connect to the ecu?
- IHaveTurbos
- <font color=red>eCtune Authorized Dealer</font><br><font color=green>eCtune Authorized Tuner</font>
No what you did would not cause it to connect. You need to look and see if whatever reason the usb port number changed.
Tim - Owner of Turbo Elements www.turboelements.com Dynocom DC-1800sz-SE
