				ectune wont open
				Posted: Sat Feb 06, 2010 11:02 pm
				by nlr808
				get a message to contact ectune on start up     MSGID 001H machine id: 69B1A7-A79396-9655A8-A8536A-6ABA0E-CA    just my luck it happens when i go to use it
				Posted: Sun Feb 07, 2010 12:01 am
				by jpjackson
				i got msgid 004H this morning and my ostrich is no longer licensed, this sucks because i got my ectune from xenocron which isn't open on the weekends, so i have to wait till Monday, and go figure, i just got my new ebc in and working good and i was going to install my new 2 bar gm map today and turn up the boost. so much for that.  i talked to Calvin and he said my machine id some how changed, and that is causing the problem, i dint change anything so i don't know. it sure sucks though, i do know that!!!
				Posted: Sun Feb 07, 2010 2:43 pm
				by nlr808
				lol i have id 1000 and a 4bar map i put on made the map about a week ago went to load it and it wont open now.
				Posted: Wed Feb 10, 2010 3:33 am
				by nlr808
				fixed thanks
				Posted: Thu Feb 18, 2010 12:38 pm
				by wolve
				i pmed calvin a week ago...    i really need my ectune to work again    i get an error while updating. it's annnoying  i can't open my ectune. probably from the 01-01-2010 problem
				Posted: Thu Feb 18, 2010 12:56 pm
				by jpjackson
				you need to send Calvin a email at calvin@ectune  or calvin@cjperformance  you might have better luck getting a hold of him there.  did you buy ectune from the web site or did you get it from another vendor?
				Posted: Sun Feb 28, 2010 12:53 am
				by HighBoostCreative
				I too cannot open eCtune and just like you all, it's right when I go to use it. Just finished up my built single cam and put 750cc injectors in now I can't even open eCtune to make a base map, let alone tune it.
     I am getting an error MSGID 006H. Going to email Calvin now also.    Steve
				Posted: Mon Mar 01, 2010 12:44 am
				by lilpooh21186
				Mine also force update no worky
				Posted: Mon Mar 01, 2010 9:00 pm
				by cquence
				This is the main reason I made the switch to Neptune. No force update and software lock out.. good luck guys
				Posted: Mon Mar 01, 2010 10:03 pm
				by timmydogg
				cquence wrote:This is the main reason I made the switch to Neptune. No force update and software lock out.. good luck guys
    just switched to Neptune myself because of this. eCtune is awesome, but this is nuts.
				Posted: Wed Mar 10, 2010 8:57 am
				people have to understand.  lock outs happen for one reason  so the software stays current.  If everybody swtiches to demon i'll remove lock outs and blocked machine id's.    So everybody switch and from end of the month ectune will never expire
				Posted: Fri Mar 12, 2010 7:35 pm
				by ryan89crx
				Any reason why Force Update wouldn't work? I get an \"old version\" error and it tells me to run Force Update...when I do, it tells me that I cannot connect to server. So now I cannot open the program, and I can't update to fix it.    I haven't even used the program yet. Had it for about a year, registered/licensed the Ostrich, now when I'm about to start tuning, I try to open the program to get a little more familiar with it and I'm locked out...
