demon drops datalog
blowngsr1
demon drops datalog
Post by blowngsr1 »
Well when i had the ostrich and hulog i never had issues with the datalog dropping or stopping. but when I put the demon in i cant datalog for more that a min or so. the to reconnect i have to unplug the usb cable then replug the connect emulator, then get rom, then connect datalog. any ideas? the baud rates are set at what the ostrich and hulog where. I 'm kinda lost on what to do next. The demon is sweet just need to get this fixed and all will be good. Wes
b20beast
Post by b20beast »
is the demon inserter properly in the socket? also are your grounds good?
Check com port settings
blowngsr1
Post by blowngsr1 »
its seated correctly port settings have not changed since i was running the hulog.
Pandor
Post by Pandor »
What (ftdi) driver version are you using? Might be related to: http://forum.ectune.com/viewtopic.php?t=2245&highlight= latest driver version is 2.06.00. http://www.ftdichip.com/Drivers/VCP.htm
Synoptic
Post by Synoptic »
I'm having the same problem. It's especially noticeable on cars with MSD systems. The Ostrich 2 does not show same symtoms though. Looks like the Demon is more sensible to EMI.
blowngsr1
Post by blowngsr1 »
any way to shield it from the EMI. in the past i have used aluminum foil to shield from it but i dont think thats a great idea in the ecu. Also the drivers are up to date that is one of the first things i did.
Synoptic
Post by Synoptic »
I realized my drivers were the buggy ones, the 2.04 one, so I upgraded to 2.06. I didint try with the 2.06 yet, will let you know.
b20beast
Post by b20beast »
Synoptic wrote:I realized my drivers were the buggy ones, the 2.04 one, so I upgraded to 2.06. I didint try with the 2.06 yet, will let you know.
any updates?
Sounds exactly like emi... How long is your USB cable, and... Is it well or crappily shielded?
blowngsr1
Post by blowngsr1 »
the cable in the ecu is the one that comes with the demon and the cable is also the one that comes with it. ill try the new drivers and see what goes down. Wes
it could be sparkplugs/emi
blowngsr1
Post by blowngsr1 »
if it is emi then how are we going to get rid of it? better grounds? wes
Maddog20
Post by Maddog20 »
resistor sparkplugs, plug wires with improved EMI shielding.
Maybe moates should consider a tin box around the deamon's components grounded to the board like a pc wifi card would have.... I know it's not helping the emi making in through the harness, but it may help... Idk :/
