Page 1 of 2
				demon drops datalog
				Posted: Tue Feb 09, 2010 1:33 am
				by blowngsr1
				Well when i had the ostrich and hulog i never had issues with the datalog dropping or stopping. but when I put the demon in i cant datalog for more that a min or so. the to reconnect i have to unplug the usb cable then replug the connect emulator, then get rom, then connect datalog. any ideas? the baud rates are set at what the ostrich and hulog where. I 'm kinda lost on what to do next. The demon is sweet just need to get this fixed and all will be good.  Wes
				Posted: Wed Feb 10, 2010 1:21 pm
				by b20beast
				is the demon inserter properly in the socket?    also are your grounds good?
				Posted: Wed Feb 10, 2010 2:22 pm
				by Almighty-Si
				Check com port settings
				Posted: Wed Feb 10, 2010 9:12 pm
				by blowngsr1
				its seated correctly port settings have not changed since i was running the hulog.
				Posted: Thu Feb 11, 2010 4:00 am
				by Pandor
				What (ftdi) driver version are you using?    Might be related to:
http://forum.ectune.com/viewtopic.php?t=2245&highlight=    latest driver version is 2.06.00.
http://www.ftdichip.com/Drivers/VCP.htm
				Posted: Thu Feb 11, 2010 4:38 am
				by Synoptic
				I'm having the same problem. It's especially noticeable on cars with MSD systems.    The Ostrich 2 does not show same symtoms though. Looks like the Demon is more sensible to EMI.
				Posted: Fri Feb 12, 2010 1:34 am
				by blowngsr1
				any way to shield it from the EMI. in the past i have used aluminum foil to shield from it but i dont think thats a great idea in the ecu.    Also the drivers are up to date that is one of the first things i did.
				Posted: Sat Feb 13, 2010 11:37 am
				by Synoptic
				I realized my drivers were the buggy ones, the 2.04 one, so I upgraded to 2.06.    I didint try with the 2.06 yet, will let you know.
				Posted: Mon Feb 22, 2010 1:05 pm
				by b20beast
				Synoptic wrote:I realized my drivers were the buggy ones, the 2.04 one, so I upgraded to 2.06.    I didint try with the 2.06 yet, will let you know.
    any updates?
				Posted: Mon Feb 22, 2010 6:21 pm
				Sounds exactly like emi...    How long is your USB cable, and... Is it well or crappily shielded?
				Posted: Tue Feb 23, 2010 4:32 am
				by blowngsr1
				the cable in the ecu is the one that comes with the demon and the cable is also the one that comes with it. ill try the new drivers and see what goes down.  Wes
				Posted: Wed Mar 10, 2010 8:53 am
				it could be sparkplugs/emi
				Posted: Sat Mar 13, 2010 8:11 pm
				by blowngsr1
				if it is emi then how are we going to get rid of it? better grounds?  wes
				Posted: Sun Mar 14, 2010 10:03 am
				by Maddog20
				resistor sparkplugs, plug wires with improved EMI shielding.
				Posted: Sun Mar 14, 2010 6:02 pm
				Maybe moates should consider a tin box around the deamon's components grounded to the board like a pc wifi card would have....  I know it's not helping the emi making in through the harness, but it may help... Idk :/
