Page 1 of 2
Message connecting to emulator (demon)
Posted: Sat Mar 06, 2010 2:19 pm
by civic4g
Hi i'm getting this message everytime I connect to the emulator since the last update. Any help?
Posted: Mon Mar 08, 2010 4:46 am
by sIrK
Hi, i have the same problem, when connect to emulator and when connect to datalog. I have problems with connection too. I have to unplug the usb, and plug in again and then do a connect. After this the ectune shows again the message of serial. All this problemas after update to last version. I have a friend that have the same problem.
Posted: Mon Mar 08, 2010 5:58 am
by 2bfi
I have that exact same problem too. It happen when I do any of the following: Connect, Disconnect, Datalog, Disconnect Datalog, any command that results in a real time update/access to the Demon.
Posted: Mon Mar 08, 2010 8:46 am
by Vtec6000
I am also having this same problem. Started happening after latest update. Any help with resolving this Calvin?
Posted: Mon Mar 08, 2010 9:45 am
by sIrK
Any solution for this problem?
Posted: Mon Mar 08, 2010 11:13 am
by sohcd16y8
Tuned a car this weekend and had the same issues with his Demon.
Posted: Mon Mar 08, 2010 1:34 pm
by TheGuardian
Same here, Im wondering if it has anything to do with the boost controller issues I've been having as well...
Posted: Mon Mar 08, 2010 2:53 pm
by Almighty-Si
Same issue here. Is there something going on with the EBC? A friend of mine has been having problems with it as of late.
Posted: Mon Mar 08, 2010 3:07 pm
by sIrK
I just installing the ebc with this ectune versión, may be the cause that i cant configure well?
Posted: Mon Mar 08, 2010 5:11 pm
by TheGuardian
Almighty-Si wrote:Same issue here. Is there something going on with the EBC? A friend of mine has been having problems with it as of late.
Yea, ive had a lot of issues lately, even my Hi/Li boost switch stopped working, and I can't get my EBC to actuate either. I started a thread explaining my problems with the EBC:
http://forum.ectune.com/viewtopic.php?t=2528
Posted: Mon Mar 08, 2010 5:27 pm
by sIrK
So, i must wait for the fix to begin to configure mi ebc, because i started to install all, the solenoid, wiring... this week with this version, not installed yet with last version.
Posted: Tue Mar 09, 2010 3:46 am
by TheGuardian
Kinda surprised Calvin hasn't showed up yet, im sure we'll be seeing him soon on this issue, it seems pretty wide spread.
Posted: Tue Mar 09, 2010 10:54 pm
by sohcd16y8
TheGuardian wrote:Kinda surprised Calvin hasn't showed up yet, im sure we'll be seeing him soon on this issue, it seems pretty wide spread.
I just emailed Calvin, he says he will take a look at these posts tomorrow to see what could be happening, rest easy tonight!
Posted: Wed Mar 10, 2010 9:34 am
i'll remove that now... it was during testing
Posted: Wed Mar 10, 2010 10:14 am
by civic4g
So can we \"force update\" or only will be corrected in R12?
