After upload cal - EBC normally closed is always set
- sIrK
Hi, when i save a calibration, and then when i want to upload to the demon, the option normally closed in solenoid configuration is alwais set and i saved this option in always open. Anybody have this same problem?
eCtune Pro & Demon rOolez! 92 Civic Turbo-Vtec at 1.5bar 300hp 93 Civic B18Dohc-Vtec Na 230hp Chrysler Neon 2.0L 16v InsanePower!
I have the same issue. Ectune has been really buggy lately. I'm kind of thinking of doing the trade in for Neptune. I have many issues with changes that don't get applied. Maybe I'm doing something wrong but I know other tuning programs don't have these issues. Try changing the boost percentage sometimes it won't make the change.
Mine keeps changing too.. Along with the crank fuel trim.. it always finds its way back to -73 or whatever.
same hea. i have it set to normally open because it is backwards, and then everytime i hook my laptop up, it switches back to normally closed, thank god for boost cut, i have forgoten to change it back a couple of times but boy does she spool fast so Calvin, how about fixxing these bugs??????????
For some odd reason I was out this weekend finally going to tune boost and I went into boost for the first time and went to look at the A/F log...nothing. It won't log anything in the boost section. Tried it a couple times, went through my settings and everything is the same as it always was so I dunno
I have mine set to NO with a GM Solenoid and I have had no issues at all. It sounds like the people who are running a NC configuration are having issues with the software switching the setting to NO when connecting to the emulator.
jpjackson wrote:same hea. i have it set to normally open because it is backwards, and then everytime i hook my laptop up, it switches back to normally closed, thank god for boost cut, i have forgoten to change it back a couple of times but boy does she spool fast so Calvin, how about fixxing these bugs??????????
