Antilag issue too much boost
Posted: Sat Mar 27, 2010 7:54 pm
by 92redhatch
I have my anti set at 7200rpm 10 fuel 10 ignition and fuel cut and ignition cut. The problem is it will boost past 20psi and I need to launch about 10 psi. Helppppp thanks
Posted: Sun Mar 28, 2010 1:24 am
lower your launch RPM until you get it where you want it... we were going to add a boost threshold for antilag but it never got done, all that kinda went out the window when we got tired of trying to make soft touch rev limiting work.
Posted: Sun Mar 28, 2010 9:58 am
by 92redhatch
Thanx
Posted: Sun Mar 28, 2010 11:13 am
by 92redhatch
I know in other programs like Neptune the more fuel the more boost
Posted: Sun Mar 28, 2010 1:59 pm
Yeah, but if your RPMs are already up where the turbo naturally makes boost you will make boost with NO antilag at all, at that point you really can't controll it unless you have a trick boost control setup. So your only option is to lower the launch RPM so the turbo won't spool up.. Once you get the revs down then you can - + the fuel/timing to get it where you want it
Posted: Sun Mar 28, 2010 3:11 pm
by 92redhatch
I didn't have that problem with neptune. My antilag was at 7200 and built on 12psi. But I guess with ectune my antilag has to be set like at 5000rpm?
Posted: Thu Apr 01, 2010 2:46 pm
probably because the antilag is less aggresive on neptune. eCtunes antilag actually works very very well. on neptune you probably were only building boost from RPM not from the antilag actually doing much..
