boost columns
Posted: Sat Apr 10, 2010 3:11 pm
by boostedsol
Is there a way to get more than 14 boost columns?? my tuner and I were trying to figure out how to add more and could no figure this out. We tried to insert columns but nothing happened and we were stuck with 14 still. Any info on this would be greatly appreciated, thank you.
Posted: Sun Apr 11, 2010 7:32 am
by TopMountGSR
I think thats all you can have unless you have it switch to secondary maps, which you can set the entire thing up to 24 more boost columns if you like.
Posted: Sun Apr 11, 2010 10:33 am
by boostedsol
interesting, so inorder for it to switch to the secondary maps i would have to wire some sort of input into the ecu to tell it when to switch correct?
Posted: Sun Apr 11, 2010 9:00 pm
why would you need more columbs? even with a 5 bar 14 boost columbs is plenty..
Posted: Mon Apr 12, 2010 8:21 am
by boostedsol
My tuner would like to see more columns so there are not large holes in the maps where you are jumping from say 10 psi to 15 psi, or is this ok?. Bugermass what would you recomend for Boost column numbers from 0 to say 40 psi?
Posted: Mon Apr 12, 2010 10:52 am
14 for boost should be enough.
Posted: Tue Apr 13, 2010 1:42 pm
I use 14 columbs for 5 bar. I've had it up to 52PSI before with no issues. You don't need crazy resoultion when in boost since its mostely linear anyways.
