EBC Wont WORK!
b20beast
EBC Wont WORK!
Post by b20beast »
So i Have a Mac Soleniod Tial 38mm Wg Setup the soleniod according to the instructions EBC Settings: Always on EBC Activation : 0.71psi Fast Spool Duty 50% Wastegate Activation 8.05Psi Fixed Duty Cycle : 50% Soleniod Config A11 Normally Closed Frequence: 25hz Anyone wanna give me any tips?
Synoptic
Post by Synoptic »
Your Error is there : EBC Activation EBC Activation should be read as : TARGET BOOST I had the same problem too, trying to figure out what everything meant. I think Calvin should make things easier to understand :)
b20beast
Post by b20beast »
Synoptic wrote:Your Error is there : EBC Activation EBC Activation should be read as : TARGET BOOST I had the same problem too, trying to figure out what everything meant. I think Calvin should make things easier to understand :)
I Cannot even get the soleniod to click. Should it click if i put, EBC Activation as 70mBar?
b20beast
Post by b20beast »
What Voltage Should A11 and Power Read?
u should have battery voltage. and a11 is a PWM GROUND what ecu r u using, did u solder in the components ur self??????
b20beast
Post by b20beast »
jpjackson wrote:u should have battery voltage. and a11 is a PWM GROUND what ecu r u using, did u solder in the components ur self??????
yes i soldered the components myself..... ecu is p28. i double checked everything in the ecu, seems fine how can i test the output from the ecu works?
Oscilloscope/ ohm meter would probably let u check it.
b20beast
Post by b20beast »
JaredKaragen wrote:Oscilloscope/ ohm meter would probably let u check it.
do i check ohms from a11 and power wire? or DCV?
b20beast
Post by b20beast »
I do not Get 12Volts from A11 to Direct Battery Power. I get 3Volts. I should See 12V Correct?
b20beast
Post by b20beast »
update POWER Wire DIRECT TO POSITIVE Battery Term key off/engine off = 12.7V [bat voltage] key on/engine off = 0.80V Engine running = 4.6V Should it not read 12V Because DATA PANE SHOWS Ebc Input Switch is Checked AND Ebc Active is Checked ? Can anyone Verify or Help me test this EBC PLEASE I Only get Wastegate Pressure I Also noticed, IF A11 IS Disconnected, i get an IACV ERROR!
b20beast
Post by b20beast »
WOOPS!!!!!! ahahha i connected the soleniod to A9, no A11, thats why i got the IACV Error! But i still do not get 12V!! I connected power to Ecu Power, and A11. Measured Volts, got like .2V or arround there. I Will try and see if i can boost later. Also, when i set Fixed Duty Cycle, why do it say -14PSI In the DATA PANE [LEFT Col]? I Still do hear the Solenoid Click ONCE with IGN on. ------------- Check something else tonight!!!! Setup Activation -15PSI Wastegate -15PSI 50% Fast Duty Spool 50% Fixed Duty USING A Digital Multimeter Connect A11 TO NEG PROVE, Connect POSITIVE PROVE TO Power I get 12V ! IF i Connect SOLENOID [a11 / Ground to] A11, VOLTS DROP!! I Read .5V Is this normal?
b20beast
Post by b20beast »
i got it working it was not hook up to A11. Now is How do i increase boost? duty cycle? fast spool? any help pls
b20beast wrote:WOOPS!!!!!! ahahha i connected the soleniod to A9, no A11, thats why i got the IACV Error! But i still do not get 12V!! I connected power to Ecu Power, and A11. Measured Volts, got like .2V or arround there. I Will try and see if i can boost later. Also, when i set Fixed Duty Cycle, why do it say -14PSI In the DATA PANE [LEFT Col]? I Still do hear the Solenoid Click ONCE with IGN on. ------------- Check something else tonight!!!! Setup Activation -15PSI Wastegate -15PSI 50% Fast Duty Spool 50% Fixed Duty USING A Digital Multimeter Connect A11 TO NEG PROVE, Connect POSITIVE PROVE TO Power I get 12V ! IF i Connect SOLENOID [a11 / Ground to] A11, VOLTS DROP!! I Read .5V Is this normal?
