EBC Still swapping to NO after program close
The bug that switches the boost control option NC/NO after close is still there. As in I select NC, and the program swaps it back to NO after saving and closing the program and reopening.
Maddog20
Post by Maddog20 »
Man, that is wierd because I have had no issues. Have you tried to make a new cal from scratch? Maybe its a hardware problem are you using Demon or Ostrich? Verify that all you com port settings are correct. Maybe good idea to use wipe the FTDI Drivers and reload and start from scratch.
Vtec6000
Post by Vtec6000 »
I assume you hit return on keyboard after change before you close the parameters window?
bug still there
patrick_yi_82
Post by patrick_yi_82 »
yup.. same problem here
can somebody point me out the exact steps i tried to replicate it. but i was not succesful to reproduce this bug..
sIrK
Post by sIrK »
I checked this... 1.-Open the ectune 2.-create a new calibration 3.-set the boost to Normally open 4.-Save the file as temp.cal 5.-Close the program 6.-Open the program 7.-Open last calibration 8.-Check the option, and is in Normally close. All the files that you open are in normally close. only is in NO when you create a new one.
eCtune Pro & Demon rOolez! 92 Civic Turbo-Vtec at 1.5bar 300hp 93 Civic B18Dohc-Vtec Na 230hp Chrysler Neon 2.0L 16v InsanePower!
patrick_yi_82
It happens to me, when I open my previously saved CAL
b20beast
Post by b20beast »
same here. when i close, and last rom re opens, it set back to NO
bigdaddyvtec
Post by bigdaddyvtec »
b20beast wrote:same here. when i close, and last rom re opens, it set back to NO
yup i couldnt figure out why my cars boost controll is all over the place. Happening to me too.
750WHP 575 TQ Leed/eCtuned H22 CD5 Trick SLUT GFI: HOLLA!!! We build FAST
sIrK
Post by sIrK »
The problem persists after update :(
solving it now!
sIrK
Post by sIrK »
Calvin, after update to r14 i have a new problem and i think that is with EBC... could you take a look to this thread? -> http://forum.ectune.com/viewtopic.php?p=24778#24778 Thank you
fixed uploading test version for pro only can somebody test?
sIrK
Post by sIrK »
I will do now. Im doing the update...
