The bug that switches the boost control option NC/NO after close is still there. As in I select NC, and the program swaps it back to NO after saving and closing the program and reopening.
Man, that is wierd because I have had no issues. Have you tried to make a new cal from scratch? Maybe its a hardware problem are you using Demon or Ostrich? Verify that all you com port settings are correct. Maybe good idea to use wipe the FTDI Drivers and reload and start from scratch.
can somebody point me out the exact steps i tried to replicate it. but i was not succesful to reproduce this bug..
I checked this... 1.-Open the ectune 2.-create a new calibration 3.-set the boost to Normally open 4.-Save the file as temp.cal 5.-Close the program 6.-Open the program 7.-Open last calibration 8.-Check the option, and is in Normally close. All the files that you open are in normally close. only is in NO when you create a new one.
eCtune Pro & Demon rOolez! 92 Civic Turbo-Vtec at 1.5bar 300hp 93 Civic B18Dohc-Vtec Na 230hp Chrysler Neon 2.0L 16v InsanePower!
fixed uploading test version for pro only can somebody test?
