Page 1 of 2
EBC Still swapping to NO after program close
Posted: Sun May 23, 2010 11:08 am
by ckretvix
The bug that switches the boost control option NC/NO after close is still there. As in I select NC, and the program swaps it back to NO after saving and closing the program and reopening.
Posted: Sun May 23, 2010 11:28 am
by Maddog20
Man, that is wierd because I have had no issues. Have you tried to make a new cal from scratch? Maybe its a hardware problem are you using Demon or Ostrich? Verify that all you com port settings are correct. Maybe good idea to use wipe the FTDI Drivers and reload and start from scratch.
Posted: Sun May 23, 2010 11:30 am
by Vtec6000
I assume you hit return on keyboard after change before you close the parameters window?
Posted: Sun May 23, 2010 1:56 pm
by yc underground
bug still there
Posted: Sun May 23, 2010 5:24 pm
by patrick_yi_82
yup.. same problem here
Posted: Thu May 27, 2010 10:06 am
can somebody point me out the exact steps i tried to replicate it. but i was not succesful to reproduce this bug..
Posted: Thu May 27, 2010 3:46 pm
by sIrK
I checked this... 1.-Open the ectune 2.-create a new calibration 3.-set the boost to Normally open 4.-Save the file as temp.cal 5.-Close the program 6.-Open the program 7.-Open last calibration 8.-Check the option, and is in Normally close. All the files that you open are in normally close. only is in NO when you create a new one.
Posted: Thu May 27, 2010 9:10 pm
by patrick_yi_82
It happens to me, when I open my previously saved CAL
Posted: Mon May 31, 2010 12:16 pm
by b20beast
same here. when i close, and last rom re opens, it set back to NO
Posted: Tue Jun 01, 2010 3:44 am
by bigdaddyvtec
b20beast wrote:same here. when i close, and last rom re opens, it set back to NO
yup i couldnt figure out why my cars boost controll is all over the place. Happening to me too.
Posted: Sun Jun 06, 2010 7:19 am
by sIrK
The problem persists after update :(
Posted: Thu Jun 10, 2010 9:09 am
solving it now!
Posted: Thu Jun 10, 2010 9:22 am
by sIrK
Calvin, after update to r14 i have a new problem and i think that is with EBC... could you take a look to this thread? -> http://forum.ectune.com/viewtopic.php?p=24778#24778 Thank you
fixed uploading test version for pro only can somebody test?
Posted: Thu Jun 10, 2010 9:25 am
by sIrK
I will do now. Im doing the update...
