ebc goes straight to boost cut
b20beast
Hey, i am having problems with ectune and my mac soleniod. no matter what dc % i set, it goes straight to boost cut. ebc activation : 10psi wg activation: 7psi fixed duty cycle 5% normally closed straight to boost cut any ideas?
thanks for the response.... the valve works 50% duty in vac, it clicks like a woodpecker so the mac valve works. i filled in the duty table lookup without actually finding the duty cycles. im hopinh thats the problem.David974 wrote:Hi i had the same problem it was a leak at the westgate no boost control= boost cut check your mac valve set activation with a vacum value , put key ON and you will hear the clicclic noise if not, you have a Mac valve electrical problem: wiring bad soldering.... check your WG vacum/boot hoses
Did you get it straitened out man?
Ok cool sounds good, The pwm control is great once you get it all setup properly.
