After R14 Still having problems with EBC
sIrK
Post by sIrK »
I cant explain in english, i show you a video... This happens after update the ectune, i dont know if is a bug with ebc or is casuality with a problem of my engine. I leave the video. The boost cut is over 1.55Bar ebc control is over gear 1.4max in 5th and 4th gear. I push the gas in 3rd and when gets 1.2bar begins to trrrr trrrt rrrr and some explosions, i cant uderstand what happen, only think that could be something with ebc control. help please. http://www.youtube.com/watch?v=-TQj4w0aSDo
eCtune Pro & Demon rOolez! 92 Civic Turbo-Vtec at 1.5bar 300hp 93 Civic B18Dohc-Vtec Na 230hp Chrysler Neon 2.0L 16v InsanePower!
9400RPMS
Post by 9400RPMS »
whats the gap on your plugs... sounds like your having some combustion issues..??
DDTech | DDTECHCAMS.COM
sIrK
Post by sIrK »
Yes, is the first thing that i supposed. But no, because this was after update the ectune, and sounds like solenoid when is working... and only does when gets 1.2bar. below this car works perfectly.
sIrK
Post by sIrK »
In second 5 is when the turbo does the trrr trrrr... at 1.2bar
just check your solenoid operation and duty cycle. u need to know if your solenoid is connect NO or NC
sIrK
Post by sIrK »
My solenoid was working well in NO. But after update to r14 have this problem....
there was bug where NO switch to NC. i just updated ectune
sIrK
Post by sIrK »
Calvin, do you know if could be a problem with EBC? this trrrrrrrr at 1.2 began to do after upgrade to r14... and i know that was a bug that now is solved with NO and NC option. My solenoid is from xenocron, a pwm and was working in Normally open option, always activate avobe 1027mbar and controlling the turbo in gear based.
NO is now solved in r14.2 release today
sIrK
Post by sIrK »
I will try to test it at this night.
sIrK
Post by sIrK »
I couldnt test the new version last night because was raining and the car dont grip well... today is raingin again, i will leave news when i test it in the car. The option when open the program and check the solenoid configuration now is ok. I hope that works fine now...
ok
sIrK
Post by sIrK »
I test the car this afternoon with new release r14.2 but when the car gets 1.2bar begins to going bad... explosions and trrrtrrr... Below 1.2bar runs perfectly.
DSMR
Post by DSMR »
Datalog? Sounds like you are blowing spark out. How cold are the plugs and what gap do you have them at?
9400RPMS
Post by 9400RPMS »
i said this early, its a gapping problem..damnt... thats what it sounds like.. its something with the plugs i doubt its ectune.
