Page 1 of 3
				After R14 Still having problems with EBC
				Posted: Tue Jun 08, 2010 4:19 am
				by sIrK
				I cant explain in english, i show you a video... This happens after update the ectune, i dont know if is a bug with ebc or is casuality with a problem of my engine.    I leave the video. The boost cut is over 1.55Bar ebc control is over gear 1.4max in 5th and 4th gear. I push the gas in 3rd and when gets 1.2bar begins to trrrr trrrt rrrr and some explosions, i cant uderstand what happen, only think that could be something with ebc control.    help please.
http://www.youtube.com/watch?v=-TQj4w0aSDo
				Posted: Tue Jun 08, 2010 4:03 pm
				by 9400RPMS
				whats the gap on your plugs... sounds like your having some combustion issues..??
				Posted: Tue Jun 08, 2010 4:06 pm
				by sIrK
				Yes, is the first thing that i supposed. But no, because this was after update the ectune, and sounds like solenoid when is working... and only does when gets 1.2bar. below this car works perfectly.
				Posted: Thu Jun 10, 2010 9:23 am
				by sIrK
				In second 5 is when the turbo does the trrr trrrr... at 1.2bar
				just check your solenoid operation and duty cycle.  u need to know if your solenoid is connect NO or NC
				Posted: Thu Jun 10, 2010 9:28 am
				by sIrK
				My solenoid was working well in NO. But after update to r14 have this problem....
				Posted: Thu Jun 10, 2010 10:00 am
				there was bug where NO switch to NC.  i just updated ectune
				Posted: Thu Jun 10, 2010 10:27 am
				by sIrK
				Calvin, do you know if could be a problem with EBC? this trrrrrrrr at 1.2 began to do after upgrade to r14...   and i know that was a bug that now is solved with NO and NC option. My solenoid is from xenocron, a pwm and was working in Normally open option, always activate avobe 1027mbar and controlling the turbo in gear based.
				Posted: Thu Jun 10, 2010 10:28 am
				NO is now solved in r14.2 release today
				Posted: Thu Jun 10, 2010 10:49 am
				by sIrK
				I will try to test it at this night.
				Posted: Fri Jun 11, 2010 6:33 am
				by sIrK
				I couldnt test the new version last night because was raining and the car dont grip well... today is raingin again, i will leave news when i test it in the car.   The option when open the program and check the solenoid configuration now is ok.   I hope that works fine now...
				Posted: Fri Jun 11, 2010 7:57 am
				ok
				Posted: Sat Jun 12, 2010 3:32 pm
				by sIrK
				I test the car this afternoon with new release r14.2 but when the car gets 1.2bar begins to going bad... explosions and trrrtrrr...   Below 1.2bar runs perfectly.
				Posted: Sat Jun 12, 2010 11:58 pm
				by DSMR
				Datalog? Sounds like you are blowing spark out. How cold are the plugs and what gap do you have them at?
				Posted: Sun Jun 13, 2010 1:28 am
				by 9400RPMS
				i said this early, its a gapping problem..damnt... thats what it sounds like.. its something with the plugs i doubt its ectune.
