Demon losing connection?
Vtec6000
Anyone else having trouble with there Moates Demon losing connection and having to close ectune and reopen again to get it to connect? Kept happening to me today while on dyno was very annoying
I bet the afr's are saved in the datalog graph, and your cell population settings for the afr reading is incorrect... Probably requiring too many hits, or conditions wrong.Vtec6000 wrote:Ok so I was on Dyno this weekend tuning a different car and the same problem happened after about 30mins on Dyno it would loose connection to demon and also I seem to have a problem with it not logging the AFR's even though it shows the Reading in data window
my cell population settings are fine as it logs the AFR every other time except when I'm on the Dyno for awhileJaredKaragen wrote:I bet the afr's are saved in the datalog graph, and your cell population settings for the afr reading is incorrect... Probably requiring too many hits, or conditions wrong.Vtec6000 wrote:Ok so I was on Dyno this weekend tuning a different car and the same problem happened after about 30mins on Dyno it would loose connection to demon and also I seem to have a problem with it not logging the AFR's even though it shows the Reading in data window
