Last update R15 - Update notification message
- sIrK
Hi, after update to r15 version, the update notification is still showing but program runs.
eCtune Pro & Demon rOolez! 92 Civic Turbo-Vtec at 1.5bar 300hp 93 Civic B18Dohc-Vtec Na 230hp Chrysler Neon 2.0L 16v InsanePower!
Calvin, notify us when finish to check if is solved. Could you take a look to my sugerence with \"display peak values\"? I told you in another thread:
Could you add the option that when closes the program remember the option in displays \"show peak values\" so when you open again the program this option is active again and you dont have to activate it again and again when you open the program..? if you want to disable it only unmark the option and then remember it when open again, that is unmarked.. I use it always to see peak values in all (rpm, boost, volt, etc...) to me is a lot of functional I asked it some time ago in a post. It could be interesting to see lower and peak values too starting always in peak values but that you could see the lowers consulting like \"show lower values\". Thank you!
Something strange happened when upadted.. I used force update.bat and shows this message when finished: I open the program and show this: And then when program is opening shows this: r14 after updated and r15 shows in opening and update nofitication message still showing.
