getting steady idle need some help
I got some 880cc injector I can get them to idle well with 13.5 A/F. I get a choppy idle if i go any leaner. I have tuned on crome for years now. With ectune on the first time i start the car with new basemap, do i increase Injector offset till i get a smooth idle or do i increase overall fuel trim. I will post my base map so you guys can look at it i did some street tuning with the injector offset @13 and the overall fuel trim at 10%.
- new tune2.elf
- (5.31 MiB) Downloaded 179 times
- F22Abisicamtune.cal
- (8.19 KiB) Downloaded 187 times
when the car is fully warmed play with injector offset until you have 14,7 afr just after you need to play with battery compensation table, put electrical load on the car (switch on every electrical devices) and tune these value, you AFR 14,7 would stay the same at every voltage load these setting will be set at idle
i have set the battery offset. I have done every thing as said above but when i get the idle to 14.7 my idle is choppy and has a pop to it. I also get some hic ups while driving around. I have been reading that larger injectors like to run richDavid974 wrote:when the car is fully warmed play with injector offset until you have 14,7 afr just after you need to play with battery compensation table, put electrical load on the car (switch on every electrical devices) and tune these value, you AFR 14,7 would stay the same at every voltage load these setting will be set at idle
Its just a 1.2 turbo cam. The idle is a lot better with ectune, when i use crome it would have very bad idle. I have a very smooth idle now just rich. I have been driving it alot this week seems alot better. I put on a h23 intake manifold a bigger throttle body.I need to get it dynoed. I am hoping for some 300+ hp numbers. this is in a civic with a h2b kit. I have a turbonetic 60 trim ar.62 exhaust. i have no traction with a lsd tranny and traction bars.
Try playing with idle ignition timing... With adjustments you can probably get afr down a lot and maintain a good idle... But this should be done after your injector offsets are tuned from 9-16v; and if you've already tried a lower fuel pressure.
Larger injectors in the older styles are inconsistant at low pulsewidths so somtimes its impossible to get a perfectly smooth idle with them at leaner mixtures. You can eithe run them richer, ignore the studders, or get rid of your resistor box and get a FJO injector driver from Xenocron. The other option is you can upgrade to some newer style FIC or ID saturated injectors like the ID1000s, or FIC 950s. The newer style injectors will compeltely eliminate your idle issues.
He speaks the truth, my fic injectors are very smooth every were, not sure if its related but my car also has the smoothest dyno graph that I've ever seen of any local hondas
- manbearpig
what is it that makes some cars have problems and other not? I have also been having trouble trying to tune a friends car on 880cc injectors, anything over 13 afr and starts to pop. I tried playing with the timing and idle speed but cant smooth it out, only thing I have not tried is playing with the fp. Does lowering the fp normally help?
When I tuned my buddy Errol's car with the ID 1000 cc injectors in and with the bisimoto 1.2 f22a cam, he was upset because his car idled all most as smooth as stock. He wanted his idle to sound lopy! I got it to idle smoothly at 14:1, around 14.7-15 it did have a slight lope. I actually miss the nice lope my car used to have on crome. Ectune is smoother.
I like smooth idle, i got it worked out. I just have to go little rich untill i get some id1000sdbsharp wrote:When I tuned my buddy Errol's car with the ID 1000 cc injectors in and with the bisimoto 1.2 f22a cam, he was upset because his car idled all most as smooth as stock. He wanted his idle to sound lopy! I got it to idle smoothly at 14:1, around 14.7-15 it did have a slight lope. I actually miss the nice lope my car used to have on crome. Ectune is smoother.
