How can I log fuel pressure?
What sensor would I use? and where would I wire it into? Would ECtune support this? thanks
http://www.auberins.com/index.php?main_ ... 04618805b6 You would just wire the output of the sensor to either the eld input or egr lift input.Then go into ectune under settings and under the analog input 1/2 (which one you use depends on which ecu input you used) and put the voltage scale from the sensor into ectunes conversion table.
http://www.aemelectronics.com/100-psig- ... or-kit-656 would this work too?
That would work.Any sensor will work as long as you know the voltage scale. With that sensor 0 psi=0.5v and 100 psi =4.5v You can get those aem sensors on eBay for a little less then 65 shipped. One other thing you might need.. http://www.radioshack.com/product/index ... Id=2062599 The sensor needs 5v to work.There are 2 ways to wire it up.Either tap the fuel sensors power from any of the 5v sensors on the car (tps or map) or run it's own power supply using that voltage regulator. I'd rather use the 1.59$ regulator then tap into the tps or map sensor, as I don't know what effect that will have on those sensors.Maybe someone else can chime in?
