Launch control & full throttle shift issues
I've used both these features on my personal cars and customer cars for quite some time, but recently, we have been having issues only on cars that use both of these features at the same time. They seem to be causing problems with each other.    From a stand still, Our launch control stops working as soon as you hit the clutch and it goes strait to the full throttle shift set rpm.    Not just happening on one car, all of them.     We are having to setup the fts to a very high rpm set point so we can launch these cars at the track. These features are not working together as they used too.     Anyone else having these issues?    We do not have problems with launch control if the customer is not using full throttle shift (isn't wired in or enabled).    Thanks for your time,  Dk
									DKGoodrich  EFI Tuning Solutions  eCtune Authorized Tuner  Frankfort, KY, U.S.A.   859-421-3334  http://www.dkgoodrich.com
I had a similar issue yesterday. I'm using a single user license. In my case, the car would use launch control as a rev limiter. If I had the rev limiter set at 7000, and launch control at 6000, it would rev cut at 6000 in any gear. Not sure if it was related to full throttle shifting, I didn't test it. I had to redo a new cal, and problem solved.
You guys could be on to something, I haven't created a new cal in a long time. Ill give that a shot.
I myself don't believe the 'upload calibration' button exists; instead I ritually push 'upload base ROM and calibration' when I first connect eCtune back in my car.    Hope it helps everyone
. USB2.0 is fast enough it's not a hinderance in doing so.
									95 Sol Si : D16z6 : TD04H-13C   74 Civic 1200 : 100% Stock
- VTEC Inside
