Another idle problem
bauboy
Post by bauboy »
Hi guys i ve got a big problem with my idle my setup d16z9 (same as d16z6) vitara eagle walbro 255 lph stock fpr 525 cc pte injectors turbo borgwarner trim 57 + ramhorn manifold It s my first tune on ectune I ve adjusted my idle with a correct afr 15 15.2 and no problem this afternoon i tune my map for my afr and no problem (street tune) but when i stop tuning and go on my home , my idle stay at 2500 3000 rpm :shock: what is the problem ???? i test changing idle on ectune and no changes i verify i havent got any vaacum leaks i disconnect the iacv and no change i turn the screw on the throttle body and no change Can you help me please???? :cry: i join my cal and a very little log because the car make noise on 2500 rpm very thanks (sorry for my bad english )
idle problem.cal
(8.19 KiB) Downloaded 271 times
idle problem.elf
(13.34 KiB) Downloaded 261 times
Recheck the tension on your throttle cable.
bauboy
Post by bauboy »
Throttle cable verified no problem when the car is cold idle is at 1500 rpm but after 20 minutes of driving the problem restart it s crazy :cry:
bauboy
Post by bauboy »
hi i resolved my problem it is the fast idle valve i change it and now idle perfect very thanks :D
Yeah I have seen a few issues with the mechanical FITV´s in my time also. Hard to diagnose until you´ve been there already :) /Allan
