eCtune and cruise cotrol?????
As the title states. I recently started using eCtune again after a while, and last night I was on the express way. So I tried to use cruise control and no luck at all. Last week I was rocking crome, using the same car, same ecu. Car did have cruise control with crome, but for some reason eCtune doesn't allow it. I'm sure it's just a simple click away, but any help is appreciated. Thanks........
Just rechecked the cal again, and nothing seems to be causing this that's related to the tune. It's weird. I keep on changing from eCtune to crome and cruise control works right away, and I'm using the emulator to run crome( I had crome running on a chip, but it's the same thing as far as cruise control).....
Correct; it should be a seperate cruise control module... its that way in all civics... cruise is 100% independent of the main ECU aside from sharing the VSS signal. Did you research the OEM manual for an accord to see if any cruise data lines go to the ECU? I am willing to guess that if it really is the cause; the fact that your using a different family ecu (p06) you are missing some hardware that is necessary.ckretvix wrote:I thought the cruise control ran off of its own "computer"?
I would agree with this 100% if both eCtune and crome would not let cruise control work, but the thing is crome does allow cruise control to function. Again, using the same car, same ecu, same everything, if I use eCtune, cruise control would not work, and when switching to crome, cruise control works right away.......Correct; it should be a seperate cruise control module... its that way in all civics... cruise is 100% independent of the main ECU aside from sharing the VSS signal. Did you research the OEM manual for an accord to see if any cruise data lines go to the ECU? I am willing to guess that if it really is the cause; the fact that your using a different family ecu (p06) you are missing some hardware that is necessary.
I searched the Accord manual for that year (and two years either way) zero interaction with the ECU. no idea why it sould be causing this... maybe eCtune is turning something off/on or removing the ECU control for something we don't know of... have you troubleshot the cruise system? you're in uncharted territory as far as I'm concerned. Time to go back to basics and step through it.
