Boost Cut and EBC Problem
Posted: Tue Jan 18, 2011 5:53 pm
by rich777
Posted: Wed Jan 19, 2011 2:44 am
by 4thgenhtch
Hey I`m richard too
Yes your vacuum is setup right, I was having the same issues theirs a glitch in the program, switch NO to NC or vice versa in the software... and go from there map out your duty cycles, for your look up tables and then you can fill out your boost by gear tables from that...
http://forum.ectune.com/viewtopic.php?t=2871
Posted: Wed Jan 19, 2011 4:59 am
by rich777
Ha Ha,
Hows it going ? Thanks for that i'll give it a go at the weekend. What about the boost cut problem ? Can anyone explain why i'm hitting boost cut ? Thank you
Posted: Thu Jan 20, 2011 2:23 pm
by rich777
Anyone ?
Posted: Wed Jan 26, 2011 12:23 pm
by rich777
Is where i'me getting the power supply from ok ? Its coming form the distributor. Thank you
Posted: Sat Feb 12, 2011 7:57 pm
by 4thgenhtch
Yea from the dizzy is fine, Whats your cut set to? So you cant get the boost to regulate? Take the line off the wg and blow into it and make sure its venting from the filter on the side...
Posted: Wed Feb 23, 2011 4:49 am
by rich777
Sorry for that late reply. I have sorted this now. I just started a new map and i don't seem to have a problem now. Strange......
Posted: Thu Mar 03, 2011 1:09 pm
by 92redhatch
Set your ebc to normally closed. And start at 0 psi
Posted: Sun Mar 06, 2011 2:06 pm
by rich777
Thank you, i'v sorted it though...
