Datalogging speed defaults to 38400
Posted: Mon Jun 06, 2011 10:58 pm
Hey all. Been a while since I last posted. I have a small issue which I'm assuming is a bug in the software. I use a tunerview 2 so to datalog I need to be set to 921600. If I set the datalogging port speed to that number hit save and then connect, everything works. But once I disconnect or close eCtune the port speed defaults back to 38400. Basically what it boils down to is, every time I connect to datalog I need to go into settings and set the port speed. Initially it was tolerable but now it's becoming a little frustrating. I looked around and didn't see anyone else mention the same issue. Any ideas?
