Question about ebc
92redhatch
Question about ebc
I've noticed when changing from normally closed to normally open my car seems to build boost a lot quicker. Is there any advantage running the ebc normally closed over normally open?
Yes. There are two types of solenoids, ones that stay normally open, and others that normally stay closed. If you reverse the values your ebc duty table is effectively reversed. So in short, it is not a good idea to run a NO ebc on a NC setting with NO values set up, as it will think high boost is low and whatnot.
92redhatch
Yes but what happens when NC fast spool is set to 0% ? Can you see whats happening ?92redhatch wrote:I know the settings are reversed. My question was referring to building boost faster. It seems that normally closed with fast spool set to 100% build boost slower then normally open with 100% fast spool.
92redhatch
