need some help tuning my ebc
ashb82
Post by ashb82 »
I got my ebc working great but i want to know if it can do this I want to do this 12 psi in 1st gear \"Simple\" then 12 psi in 2nd but work its way up to 18 psi by 8000 then 18 psi in 3rd \"simple\" I need this because i like to race a class at my local track that only allows street tires. I have been using i button to activate high boost setting. but i cant get consistant as i like.I run consistant 8.3 @ 95mph 1/8th, but traping 95 mph i shoud be deep in the 7s.
92redhatch
Post by 92redhatch »
Use the boost compensation tables. I go 104mph in the 1/8 in 7.5 on slicks. With a crappy 1.8 60'. Ive been 7.8 at 90mph
ashb82
Post by ashb82 »
92redhatch wrote:Use the boost compensation tables. I go 104mph in the 1/8 in 7.5 on slicks. With a crappy 1.8 60'. Ive been 7.8 at 90mph
But would it do this in every gear. i only want it to do it in 2nd
You would need to program something like an atmel processor to read the pid for gear, and enable a high/low boost input/setting in ectune.... Tis the only way so far, without a major revision to the rom.
magi111
Post by magi111 »
Thank you for posting such a useful, impressive and wicked article. wow looking good...!!! Tires Miami
