input vs output
Posted: Wed Sep 21, 2011 9:10 pm
by xjdmjunkiex
im wanting to use gpo to send 12v power to activate a device i have, at a certain rpm...how would i go about doiing this using gpo? what is the difference between selecting the input or output?
Posted: Thu Sep 22, 2011 10:42 am
by relic1
input - on signal the software does something. output - software hits criteria and turns on/off output **edit for more info now that I have eCtune on a local computer.** enable GPO ? output - which ever hardware output you want to use input - hardware input criteria options - what you want done when the input/output conditions line up. conditions - what has to happen to trigger adjustments – what you want done to fuel or ignition example: (I’m making this up in my head) flip switch in dash wired to B8, at operating temp and WOT, switch to secondary maps and turn on A15 which drives nitrous solenoid. [input & output]
Posted: Thu Sep 22, 2011 2:17 pm
by xjdmjunkiex
hmmm not suer im understanding this correctly
Posted: Thu Sep 22, 2011 3:06 pm
by relic1
edited the above post to include more info. (I was editing when you posted) hopefully that helps. I'm happy to step you through if you have questions.
