Thanx Allan, can you direct me as to how to disable the STS Starter Signal ?? Thanx for the helpBindegal wrote:Good you good the logging sorted out. The only reason I can see for the fuel pump to run constantly (when the Off-setting works) is if the ECU somehow thinks the car is cranking. Cranking is detected by the distributor sensors but also there´s a STS Starter Signal input that can be disabled... /Allan
Cant Connect to ECU
93 Honda Civic - 10.00 @ 153 95 Honda Civic - B20Vtec Turbo Street car
Parameters, Sensor/Hardware options -Disable STS(Starter Signal) input ...if you don´t have this option available, try pulling out B9 at the ECU. This is pure guesswork on my part, I haven´t seen this problem before, ever.... /Allan
STS was disabled on the ECU - I de-selected this and the fuel pump primes as its supposed to now ! Many Thanx for the helpBindegal wrote:Parameters, Sensor/Hardware options -Disable STS(Starter Signal) input ...if you don´t have this option available, try pulling out B9 at the ECU. This is pure guesswork on my part, I haven´t seen this problem before, ever.... /Allan
