AFR Target and AFR % Change Tables
extreme-eg
Hi guys As I'm new to eCtune - I'm trying to figure out how to let the ECU log and input AFR readings from my wideband in the AFR \"log\" table (AFR estimated % change) From reading another post it seems like there is an activation threshold like temp etc. > Where should I be looking to make sure this function is right ? I've seen and used this facilty on Neptune on a cutomer's car and it certainly appears as if eCtune can do the same - is this correct ??
93 Honda Civic - 10.00 @ 153 95 Honda Civic - B20Vtec Turbo Street car
extreme-eg
