Need input from Calvin/Nate/developers
I was wondering if Calvin completely cut out the oem egr routine. I was wondering if it could be used; and have the root heuristics added to the software... I am doing a little development, trying to figure out the realisticness of using the egr as a \"bypass\" valve for forced induction. I already have the obd2 manifold with valve installed; but don't want to have it as an on/off, nor do I want to take over the ebc function..... Because it varies duty based on boost, not the other conditionals.
As far as I know, the P72 code has no EGR at all. So its not removed but not present also.
I may turn to my arduino on this one then... :)
