Ostrich to Demon
NESof NOLA
Ostrich to Demon
Post by NESof NOLA »
Im having problems connecting to the ecu with the newer software. I had heard others were having problems as well and switched. Is there a way I convert my license from Ostrich Pro to Demon pro?
To move from an ostrich to a demon you need to contact Calvin, also there a 25$ fees
I always used an ostrich. never had problems. do you use good shielded cables?
Inu experiences I have found the demon to be more unreliable in connection issues than the ostrich; in fact the ostrich is extremely solid and reliable. Every demon customer of mine that gets tunes on ectune (or any applicable ems); I tune them on my license/ostrich, then upload that .cal to their emulator in the end... no worries about disconnects and what not, and no breach of licensing. I have all my hardware inside the PCM case with 2 USB cables and the LM2 analog out cable hanging out of the case. Each of those has a ferrite bead on the end, same with all other USB/power cables in my tuning gear. Ostrich connection issues are few causes that I have come across: Emi: hid's, ignition mods(nology wires, msd, etc), etc Bad grounds Faulty/old cables
cain_tuned
Post by cain_tuned »
ya i have issues with my demon also my ostrich is way more solid i just hate having to deal with the hulog .
I'm starting to think it's just the demon board & firmware itself. Notice lot of connection & freezing issue with multiple demon setups, and not just with eCtune setup.
