Fan Control
Fan Control
I noticed that when I enabled fan control without selecting an output, it disables the A/C.. Can we change fan control to default to Fan Relay instead of A/C request?
I thinking it makes more sence to have it default to Fan Relay control, if somone has a single user version and just enable it thinking its gonna turn their fans on at the set temp but instead their A/C cuts off it could be a bit confusing. more of a useability thing not so much a bug.
will do. but.. Fan Control: You should wire a cable from fan output(ecu) to the thermostat housing fan switch. i don't think it works by default... Or maybe only when AC is also on.. Who can verify that?
