How to rescal the fuel and ignition map for boost.
Posted: Tue Oct 16, 2012 8:35 pm
by dyno
I have 6 or 7 row for the boost table on my map, the problem is 2 row are alot to hi on boost value and I will never go there so y will so y whant to have more usable point.
Posted: Mon Oct 22, 2012 9:33 am
by Bindegal
You can add, and insert columns more or less as you please. That way you can kill unnecessary resolution where you don´t need it - and add it in where you do need it. From memory: Just highlight the column (mbar/psi) and right-click to see options. /Allan
Posted: Mon Oct 22, 2012 6:23 pm
by dyno
Thanks
