Map Sensor Voltage
Posted: Wed Jul 11, 2007 8:09 pm
On every car I've done in last 5-6 weeks, I've enable my baro sensor and compared to my map sensor with the engine off. With the stock honda map sensor selected it never matches. I can usually get it to perfectly match within 1mbar if I set the minimum voltage to -70.. this also seems to clear up any rich AFR on decel and any fuelcut issues. has anyone else noticed this? I think either my baro sensor is off or theres a bug in the map values settings.
Posted: Wed Jul 11, 2007 9:35 pm
by Joey Misanthropy
You are correct.
Posted: Thu Jul 12, 2007 8:10 am
Then i have to change it in the baseBin and ectune... Will do now THanks
Posted: Thu Jul 12, 2007 8:20 am
done
