Gpo1 issue
koupanos
Gpo1 issue
Post by koupanos »
Hi i have a problem setting my gpo1, i have put an electo-hydrolic pump for power steering and i want to control the pump from the ecu , i want it to work only for certain rpms an km/h,when i set the limits the ecu send only a blink at the test led and the the gpo1 is off . For example i have set it to work min 800rpm and max 3000rpm with 0km/h and 0tps its only send a command when the rpm passes 800 and then stops. can you help me pls
Civic turbo
you cant have it trigger on than ofd at different rpms, only on or off between certain rpms.
koupanos
Post by koupanos »
Thanks jared i have worked it out :)
Civic turbo
