				can't request ostrich license
				Posted: Thu Apr 27, 2017 2:17 pm
				by ricardo_v
				Just installed fresh to a new laptop (win10). Got the license a few days ago. Now when I want to connect the ostrich to ectune. I push request license and I'm getting a screen which only say's error. Is a bug in the software or something windows 10 related?
				Posted: Thu Apr 27, 2017 2:18 pm
				I just made a how-to for installing eCtune on win10:    1-  disable UAC  2-  unpack eCtune.Setup.current.rar file  3-  run as administrator: setup.exe  4-  Open whatever directory that eCtune is installed to, usually Program Files (x86)   5-  Right click on eCtune folder, click \"Properties\"   6-  Under the \"Security\" tab, click \"Edit\" (Change permissions)   7-  Click your logon name under the \"Group or Usernames\" menu   8-  Next box down \"Permissions for ALL APPLICATION PACKAGES\", click Full Control > Allow   9-  Click ok to exit all the settings prompts.   10- Start menu > All apps > eCtune > Force update   11- Right click on the eCtune shortcut on the desktop, click \"Properties\"  12- Click \"compatibilities\" and check \"run as administrator\"  13- Double click the eCtune shortcut to start the program.  14- Register your ostrich in the Emulator menu  15- Go to help, choose registration.  16- Fill in the form and press \"register online\"  17- When you get your license file, save it in the eCtune directory.    done!      Let me know if it works
				Posted: Thu Apr 27, 2017 2:51 pm
				by ricardo_v
				just uninstalled ectune, followed youre steps exept that i did step 15 before I paired the ostrich otherwise ectune tels me it can't detect a demon.     Got the license can connect to the ostrich but keep getting the error screen on requesting license
				Posted: Thu Apr 27, 2017 3:58 pm
				mmm, I never had a demon so I cannot test a demon in combination with win10.
				Posted: Thu Apr 27, 2017 4:35 pm
				by ricardo_v
				Probably miscommunication on my behalve, I have a ostrich nota demon.I'l try to explain what ive done    When I install ectune fresh it says Pro_demon.    I have a ostrich so before I can even enter the \"moates emulater\" under the \"emulater\" menu to connect to my ostrich and request a license ( step 14 in youre 17 step program). I need to register under the \"help\" menu and registration button (step 15)    I did step 15 a couple of days ago en got my license. Now i copy the license to the ectune directory en then when i start ectune it says that i got the pro ostrich version.     But when i want to use the ostrich it says: Ostrich not licensed or vendor not eCtune. so i go to emulator info and click the request lic button and then i am getting the error screen.    But I think its something to do with windows because i tried to request a new license for test purpose (step 15, filled everything with test) and got the message that a new license was requested.     closed ectune and restarted ectuen, tried to request a license again with my own credentials (also step 15) and got the same error message. Its like somthing is blocking ectune to perform a license request
				Posted: Thu Apr 27, 2017 5:26 pm
				by ricardo_v
				Just requested a license for my old laptop. If you could acknowledge the request hopefuly i can use ectune again.
				Posted: Fri Apr 28, 2017 12:50 am
				onder welke naam? of email?
				Posted: Fri Apr 28, 2017 12:53 am
				[email protected] gaat niet werken. De request is binnen maar de server heeft je mailadres nodig om te kunnen versturen.
				Posted: Fri Apr 28, 2017 4:30 am
				by ricardo_v
				heb je een pm gestuurd met mijn email
