Bindegal wrote:I haven´t really tried it. If you´re seeing some specific issues I will happily try to reproduce them here. /Allan
i don't have 64bit yet. im getting a new laptop and was wondering if i should choose the 64bit vista option. i wonder if ectune will run on 64bit vista? i wonder if it matters?
Unless you plan on using more than 4GB memory in your laptop I would stick to the 32 bit version. Not so much from personal experience, more a matter of \"we fear change\" /Allan
so i'm using a demon with ectune and it worked for a bit and froze up a few times. Now i'm having major trouble, won't connect anymore at all my friends laptop connects but then gives errors and the fuel graph is a white box with red lines. . . .anyhelp would be great thanks
reinstall all .net frameworks... make sure UAC is disabled and run ectune as admin
Ok I just got a new laptop and disabled UAC and enabled run as administrator, and I am still getting the same error as if I did not disable UAC. I also got the new .net framework from windows just to make sure that was not the problem. I am using 64 bit windows 7. I understand that you can remove UAC from the registry with regedit or something, I might look into that if all else fails.
dbsharp wrote:Ok I just got a new laptop and disabled UAC and enabled run as administrator, and I am still getting the same error as if I did not disable UAC. I also got the new .net framework from windows just to make sure that was not the problem. I am using 64 bit windows 7. I understand that you can remove UAC from the registry with regedit or something, I might look into that if all else fails.
Exactly what issue are you having?
I was getting the msgid 004. Which is the same as I have gotten before when UAC is enabled. I thought that the license file only related ectune to the ostrich. I forgot that machine ID was involved. Long sort short, removing the license file solved the issue. Unfortunately it still is not working because apparently I have to have the xenocron ectune installer. Hopefully I get a response from Chris soon.
if you registered with his installer and use the same email address as previous registration it's fast
