Bug Map trace/ Copy paste afr grid in 1.9r1
Posted: Mon Jul 23, 2007 10:16 pm
Just a couple things i notice, 1. A/F target overlay cashes when you do a Ctrl c, to copy a area then switch map either from high to low and do a Ctrl v to paste it then cashes ectune, not allowing you to paste. 2. Map trace stop showing map trail color after i view a log with the log still open and going to settings to make changes to overlay condition. Cant get the map trace trail to display the area's of the map after this. Try different logs still the same results uninstall & install same results.
