Fixes in R3
Posted: Thu Aug 30, 2007 11:50 am
Fixed so far: -Psi boostcut editable(still doesn't work as i want, i'll put a drop down to select psi/mbar/ect) -Map scalar editable in native display format(e.g. Psi) -Target AFR set and (incr/decr) bug -Close CTRL-J(adj selection) with Esc -Close Timing Sync with Esc -Min Mbar honda mapsensor changed to -70mbar -Boost cut 1200 RPM bug -Hardcoded ISR baud -Detection of J12/J4 Jumper Working: Moates Encryption/Pairing P.S. Very little time now due to a Job I took
Posted: Thu Aug 30, 2007 1:09 pm
by RoadXY
Any update on the logger version?
Posted: Thu Aug 30, 2007 3:54 pm
All the version are the same. License differance only.
Posted: Fri Aug 31, 2007 4:33 am
by RoadXY
Cool, thanx! Is it already downloadable on the website or?
