map sensor
map sensor
i was wondering if there is a list of the compatible map sensors available for ectune. i have to sensors, and im not to sure on what bar they are, i belive they are GM map sensors as well. Here are the part numbers, 09359409 with a four digit code of 3246, and the other is 16165793 with a four digit code of 3237. thank you
I searched 10 sec on google and found you answer; http://www.powerandsignal.com/docs/Prod ... ochure.pdf You can search yourself.. And no, we dont have all the 73657409 different map sensors of this world in the software. For that you can edit your own map sensor.
