map sensor
Posted: Wed Sep 12, 2007 10:26 am
by boostedsol
i was wondering if there is a list of the compatible map sensors available for ectune. i have to sensors, and im not to sure on what bar they are, i belive they are GM map sensors as well. Here are the part numbers, 09359409 with a four digit code of 3246, and the other is 16165793 with a four digit code of 3237. thank you
Posted: Wed Sep 12, 2007 3:47 pm
I searched 10 sec on google and found you answer; http://www.powerandsignal.com/docs/Prod ... ochure.pdf You can search yourself.. And no, we dont have all the 73657409 different map sensors of this world in the software. For that you can edit your own map sensor.
Posted: Wed Sep 12, 2007 4:56 pm
by nate
As long as you know the voltage scale of the sensor, you can use whatever...
Posted: Wed Sep 12, 2007 6:00 pm
by boostedsol
i didnt even dawn on my to google it up, so for that i am sorry.. so if the voltage scale of this sensor is 0-5 volts i should beable to use this with ectune correct
Posted: Thu Sep 13, 2007 1:12 am
Yep!
Posted: Thu Sep 13, 2007 7:18 am
by boostedsol
sweet. thanks for the help guys. cant wait to get this thing done and tuned on ectune
