My ostrich pairing test
Posted: Tue Oct 16, 2007 7:27 am
...was successful. 1. Update Ostrich firmware to 1015 version and select the new \"eCtune Ostrich\" within eCtune. 2. Connect, Open Ostrich Info in the menu. 3. Reset vendor ID. 4. I selcted Obtain license. eCtune seemed to tell me that it had requested a license (I was connected to the Internet at the time) but I didn´t see a confirmation email as I do when normally requesting an eCtune license? 5. At this point the Ostrich operations are (intentionally) not allowed as it is \"Unlicensed\". 5. Sent the serial number (cut&paste) to Calvin manually via email as I was not sure eCtune had done so automatically. 6. Received a new license.xml. 7. Installed new license. Ostrich is now licensed and I tried write and verify without problem. (test was done without access to a car though) To me it seems the system is working as intended. My conclusion: Good work! One thing though, and this is probably more related to Moates than it is to eCtune: \"normal\" Ostrich operations through the old \"Ostrich_1_2\" or Cr### didn´t work for me any more after firmware 1015 was installed. I assume other vendors have to adjust their software to the new protocol or whatever. My point is: Customers/users need to be aware of this. /Allan
