0.0.2.4 7/24/2009 - LM-2 Support - X - Read chip pro version disable - X
0.0.2.3 r5 8/25/2009 - Version number moates devices. - X
tuner link will be mail in a few hours
0.0.2.3 r6 9/24/2009 - Expire update --------------- 0.0.2.3 r7 10/24/2009 - Update larger then 100 do cal upload(burgermass) -OStrichECT - TESTED -ostrich v1/v2 Tuner not tested -Demon not tested -DemonOLD not tested --------------- 0.0.2.3 r8 11/24/2009 - Update larger than 100 do cal upload(burgermass) -OstrichECT - TESTED - X -Demon - TESTED - X -ostrich v1/v2 Tuner - Tested - X -DemonOLD - not tested
0.0.2.3 r9 PRI edition rom 0.0.65 -Fix Fuelcut settings (TPS AND MAP) thershold fixed - X -Fuelcut Vacumn leak settings adjustable - X -adjustable RPM for cut off - X -Adjustable Tps thershold - X -Enable/disable Vacumn Leak Fuelcut - X - multiple demon bug fix(nick) - X - emulator info(20.09.O/01.07.D) same as moates apps(craig) - X - VSS threshold for burnout control(blake) burnout disables as vss > 0 bug - X Burnout has priority over FTS, FTL - dwell correction -rpm phase table -human readable values - X -extended range to 11k rpm - X -battery offset phase multiplier table -Human readable values - X - stock ign limitations based on rpm row -Default disabled by eCtune sinse rom 0.0.46 -X - injector dynamics data(locash) ID 725 - X ID 1000 - X ID 2000
0.0.2.3 r13 PRI edition - injector dynamics data(locash) ID 725 - X ID 1000 - X - FV enable again - X - EBC NC/NO FIX - X - DISABLE quick upload demon lock up - X
0.0.2.3r15 6/30/2010 - Expire date removed MSGID 002h removed- X
